04-18-2006 03:15 AM
05-01-2007 02:58 PM
04-02-2008 03:48 PM
I bought the same card (supermicro PDSBA) but I'm running into problem.
I formatted the SATA hard drive in FAT32 and then formatted the drive with the disk created in MAX.
When I try to start the RT Desktop, I get the following message "Starting LabVIEW RT...... Could not find RT OS on disk..."
In the BIOS, I selected the option "compatible" for SATA drives.
Partition FAT32 - 32Gb
LabVIEW RT 8.2
Can someone help me to find out the root cause of problem ?
Nicolas
04-03-2008
12:51 PM
- last edited on
04-21-2025
10:08 AM
by
Content Cleaner
Nicolas,
Please take a look at this knowledgebase.
"LabVIEW Real-Time does not support Serial ATA, however the following options may be available depending on the specific desktop PC.
Also ensure that SuperMicro PDSBA has a chipset supported for LabVIEW Real-Time.
04-03-2008 02:43 PM
Thanks for your reply.
I went trough this problem. The problem is that the Pharlap formatting disk is not setting the partition as active.
I had to set up manually by running fdisk from a dos boot disk. and now it boot on it !
But still a problem. The Ethernet chipset on the board is a 82573L. This chipset is supported on LabVIEW 8.5 but I'm using 8.2...
So I disabled the onboard Ethernet with a jumper on the motherboard and insert a PCI card INTEL Pro 100 /S (dual port) with chipset 82550GY; I suppose it's supported since the 82550 is supported. But each time I started the system I get the error "unable to configure the primary network device....".
I also tried with the safemode disk; still the same problem.
By the way, concerning the HD; I formatted this Harddrive with FAT32 format for the partition size of 80Gb. Is this supported or do I have to limit the partition to 32Gb ?
Thanks for your help
Nicolas
04-03-2008 05:44 PM
04-07-2008
11:24 AM
- last edited on
04-21-2025
10:08 AM
by
Content Cleaner
Hi Nicolas,
Have you tried this after installing the latest version of the DAQmx drivers? The latest drivers can be found here.
Please check the readmes for compatibilty before you install the drivers.
07-09-2009 03:39 PM
I have a similar problem.
Labview 8.5.1 Dell Optiplex 755 with quad core and gibabit Broadcom Netxtreme as the 2nd NIC. Serial ATA
It passes the evaluation test, works in the safe mode and for normal booting gives " Unable to configure the primary network device"
Broadcom NIC is recognized as BCM 57xx.
I am booting from the USB stick.
Any help is appreciated.
