 cys
			cys
			04-01-2008 09:19 AM
		04-02-2008
		12:25 PM
 - last edited on
		09-04-2025
		01:30 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Chen,
Have you verified that the computer meets all of the Requirements of a Deskstop PC as a Target?
The "unable to configure primary network device" error you are receiving occurs when you cannot obtain a DHCP address. I would first recommend reformatting your target PC. MAX does have the option to boot from a disk as opposed to a thumb drive. If you select RT Disk Utilities, the third section has options for desktop PC disks. Take a look at the document on Using Desktop PCs with LabVIEW RT for specifics on formatting, configuring, booting, and installing software on the target.
Lauren
 bcaudana
			bcaudana
			09-25-2010 04:46 AM
I have the same problem of Chen. I cannot connecto to the target (in my case a Siemens Rack PC). I consulted the documentation quoted but with no success (by the way... the KB quoted is unreachable).
Now I cannot even generate a USB boot key.
My complaint is also more general: why NI products never work as declared (and frequently never work at all, when one wants to do real applications and not simple toy demos)?
Thank you.
