NI DAQ 6361 Generate voltage upon trigger and stop generation upon stop trigger
I have been working to generate a voltage upon trigger, where upon the voltage detected on the analog input reaches 2.0V, a voltage will be generated in the output. However, when the voltage detected on the analog input is below 2.0V, no voltage will be generated in the output.
I have been thinking about using DAQmxCfgDigEdgeStartTrig() function to start the trigger, but how do i stop the trigger?  So far what I have found out are reference triggers to stop voltage acquisition.
Is there any way to stop voltage generated at the stop signal?
(2,461 Views)
I would like to clarify that once the trigger condition(the falling edge) is met, the voltage output will stop.
How do I do that?
(2,460 Views)
I'm not totally clear what you mean by "voltage output will stop" does that mean output 0 Volts or are you trying to tristate the output?
Would something like this work:
https://forums.ni.com/t5/Example-Programs/DAQmx-Generate-Acquired-Data-Software-Timed-Single-Point/t...
If you are looking for a hardware based solution maybe the folk over at Multifunction DAQ could help out.
My inclination is to checkout the "analog triggering" section in this article:
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
to generate a trigger for your analog output.
(2,431 Views)
