Using PXIe-6363 with DAQmx inside Scan Engine timed loop?
Hi together,
in our application a PXI-1078 chassis is connected to multiple NI-9145 EtherCAT expansion chassis. Measurement data are acquired via Scan Engine. Is it possible to add the PXIe-6363 card into the Scan Engine time loop somehow? (This card doesn't show up in the project tree).
I think I can only access the signals via DAQmx...
Lysandros
(2,210 Views)
Check out the DAQmx example at
C:\Program Files (x86)\National Instruments\LabVIEW 20xx\examples\DAQmx\Analog Input\Voltage - Timed Loop.vi
(2,195 Views)
