09-19-2018 07:18 PM
I have been working to generate a voltage upon trigger, where upon the voltage detected on the analog input reaches 2.0V, a voltage will be generated in the output. However, when the voltage detected on the analog input is below 2.0V, no voltage will be generated in the output.
I have been thinking about using DAQmxCfgDigEdgeStartTrig() function to start the trigger, but how do i stop the trigger? So far what I have found out are reference triggers to stop voltage acquisition.
Is there any way to stop voltage generated at the stop signal?
09-19-2018 07:24 PM
I would like to clarify that once the trigger condition(the falling edge) is met, the voltage output will stop.
How do I do that?
09-20-2018
01:22 PM
- last edited on
10-16-2025
05:29 PM
by
Content Cleaner
I'm not totally clear what you mean by "voltage output will stop" does that mean output 0 Volts or are you trying to tristate the output?
Would something like this work:
If you are looking for a hardware based solution maybe the folk over at Multifunction DAQ could help out.
My inclination is to checkout the "analog triggering" section in this article:
to generate a trigger for your analog output.
