NI driver for Sonix STR8100 D board
We have Sonix STR8100 card that works with DOS-based data aquisition
software and want to have this card to work with a LabVIEW driver in windows XP.
(6,698 Views)
Accepted by topic author Koye88
How do you intend on communicating with the card? What protocol will you be using?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(6,691 Views)
Hi Koye88,
Thank you for contacting National Instruments. I'm afraid we need a little more information in order to help you with this request. As Adnan asks, how are you communicating with this device? You mention that you are using a DOS based Data Acquisition device, who is this manufactured by? Is this an NI Data Acquisition card? Do you have any documentation about this particular device that we could look at?
If I can make a few recommendations about posting
1. Always include as much information as possible; the more information that you provide, the more likely you'll get a helpful answer
2. If you are using third party equipment, try and provide either datasheets or resources so that others can get up to speed on what you are trying to use.
3. If you have an existing setup that works, try and give a detailed picture as this can help when developing a newer solution.
4. If at all possible, please try and avoid posting the same question multiple times as this spreads the collective effort rather than concentrating it. In the long run, finding a solution will take longer.
If you can give us a bit more detail on what you are trying to do, we shall try and assist you.
Many thanks,
Andrew McLennan
(6,655 Views)
Thanks for the information.
There is a SONIX STR-8100 D digitizer card for Data Acquisition.
This Sonix STR8100 works with “Winspect” Data Acquisition Software.
I am looking for LabView Drivers for Sonix 8100 Digitizer card.
Kometa
(6,630 Views)
I believe I haven't provided a solution to your question; if so, you shouldn't mark my post as one. Again, you will need to tell us what kind of protocol/bus you are using to communicate with the card. If it's PCI based what kind of driver is provided with the card? For example, if you have a DLL interface, you can easily call that using LabVIEW.
Message Edited by Adnan Z on 08-25-2009 03:14 PM
Adnan Zafar
(6,613 Views)
Here is the  SONIX STR100 card specifications
Trigger: · Sources; software, external TTL, 256 level digital threshold
             · Modes ; normal, pre-trigger-delay from 0-262K samples
Memory Buffers · 64K high static RAM
                         · Segmentable in 4byte increment
                         · Addressable at 16K boundaries through a 16K window in user memory
                         · Analog DC-50 MHz bandwidth, -3dB
                         · .125 to 2V input range, software selecatable
 A/D conversion · 100 MHz base rate
                         · 8 bit flash converter
                         · 200, 400 and 800 MHz equivalent time sampling
Features · Installs in XT or AT type slot
              · 8 bit or 16 bit data transfer
              · Interrupt on acquisition complete
              · Trigger input/output connector
Software · Each board comes complete with a two channel, real time digital oscilloscope program
              · C callable assembly language drivers, source code for easy modification to other high level language calling protocols and sample programs
               · Optional Digiscope, Spectrum analyzer and Data acquisition programs are also available
(6,585 Views)
Hi Koye88,
I sent a query off to Sonix to try and find some information about this board but I have not been able to find anything about  this particular part.
If you could post any information you happen to have about this part that would be greatly appreciated. It woulld also be useful if you could provide a link to any drivers that you have, regardless of whether or not these are LabVIEW or not. This will help with trying to work out how to get this setup working.
Andrew McLennan
(6,350 Views)
