RT Get CPU Loads.VI returns error -2233 with RT startup executable
I've used RT Get CPU Loads.VI with success in development mode on several cRIO targets, but when running as a startup application on a cRIO-9045, I receive:
error -2233  Unable to retrieve CPU load information. Verify that CPU load monitoring is enabled on the target.
I'm not sure why the behavior is different with a startup application from development mode.  I've tried placing a delay of up to 120+ seconds before making the call to be sure all OS services are loaded, but this doesn't solve it.
I appreciate any replies, but before answering that this VI is deprecated please see my other question here:
https://forums.ni.com/t5/Real-Time-Measurement-and/Alternative-to-RT-Get-CPU-Loads-VI/m-p/3910660
(3,049 Views)
Accepted by simplemaan
Hi simplemaan,
What version of LabVIEW are you using?
It looks like this may be a Known Issue with some versions. If so the workaround is to Disable Embedded UI.
-Noah
Noah B.
Technical Support Engineering
(3,019 Views)
Thanks for pointing this out.  The embedded UI is enabled on the RT.
(2,995 Views)
