Runtime LabVIEW works with real-time target control?
Not in developing but when implementing the system (CRIO)./ and more than one CRIO in the same time
I want the CRIOs can be controlled from a host computer.
What should I do?
Can I use LabVIEW run-time, because its free license.
Thank you for your suggest.
Engineering at Sriracha
Kasetsart University
(4,444 Views)
Hi Yaovaja,
There is a difference between the Runtime and the Real-Time engine. The Runtime engine is for operating systems without LabVIEW installed. The Real-Time is for realtime operating systems. \
The Runtime Engine will not take the place of the Real-Time module, you will need a licensed version of the Real-Time module to program the cRIO. However, your university may have this option already if they have a site license for labview. You can double check with your IT department.
Once you have the Real-Time module installed you will be able to control multiple cRIOs from the same computer without problems.
Jesse Dennis
Engineer
INTP
(4,430 Views)
THANK YOU VERY MUCH
I will program cRIOs with my host computer which fully Labview installed.
Then
Can my another host computer which installed only labview run-time connect/control to multiple real time systems via an .exe labview file?
thank you
(4,398 Views)
Accepted by Yaovaja
Hi Yaovaja,
Once you have the cRIO programmed with a startup executable you will be able to communicate with it through shared variables or network streams or a communication method of your preference. You can use these communication methods from an executable. So yes, you can communicate, you just can't program the cRIO.
Jesse Dennis
Engineer
INTP
(4,396 Views)
