02-18-2009 04:20 AM
In a Labview project, Scan Engine period can be set to up to 1 μs, but the document at http://zone.ni.com/devzone/cda/tut/p/id/7338 says that the Scan Engine updates the I/O variables at up to 1 KHz. This is not clear to me. Is the 1 μs period meant only for counters, PWM etc? For normal I/O what's the point in scanning faster than 1 ms if variables are updated at up to 1 KHz anyway?
Solved! Go to Solution.
02-18-2009 08:37 AM
02-18-2009 09:03 AM
02-18-2009 09:53 AM
02-18-2009 10:00 AM
02-18-2009 10:40 AM
02-18-2009 03:24 PM
12-11-2017 10:15 AM - edited 12-11-2017 10:15 AM
I unearth this topic because I don't find any information about the minimum scan engine period on a RT PXI controller (LabVIEW RT). All topic are about scan engine period on a PXI with VeriStand.
In my case I want to develop a real time application on a PXI which is used Ethercat which means scan engine Loop. I just need to know if the minimum period is the same as on a cRIO ( 1ms) and have some bechmark about reading and writing variables.
Thanks for your answer,
