04-19-2017 01:26 AM
Hello.
I have learnt the basic programming. Now I want to get deeper into the language. For that, I presume, I'd need a hardware to work with. Can you suggest me which is the economical hardware that would be suitable for learning purposes? Thanks
Solved! Go to Solution.
04-19-2017 03:42 AM
1. Which language are you referring to?
2. What types of applications are you looking to do?
04-19-2017 04:17 AM
Hello CrossRulz. Thanks for the reply.
1. I'm referring to LabVIEW.
2. I want to build a control/interlocks to a real-time process.
04-19-2017
05:53 AM
- last edited on
12-18-2024
03:01 PM
by
Content Cleaner
In that case, look into a myRIO. It is technically for academic, but it is available. Another option is the RIO Evaluation Kit.
04-19-2017 06:05 AM
They are a bit expensive. Can I connect any third party hardware? Any suggestions?
