Suitable Hardware
Hello.
I have learnt the basic programming. Now I want to get deeper into the language. For that, I presume, I'd need a hardware to work with. Can you suggest me which is the economical hardware that would be suitable for learning purposes? Thanks
(3,278 Views)
1. Which language are you referring to?
2. What types of applications are you looking to do?
(3,254 Views)
Hello CrossRulz. Thanks for the reply.
1. I'm referring to LabVIEW.
2. I want to build a control/interlocks to a real-time process.
(3,251 Views)
Accepted by Ganny
In that case, look into a myRIO.  It is technically for academic, but it is available.  Another option is the RIO Evaluation Kit.
(3,246 Views)
They are a bit expensive. Can I connect any third party hardware? Any suggestions?
(3,242 Views)
