Unable to connect to the fpga compile server
Hey Andrew,
I have the same problem. I am not able to connect to the NI Cloud Compile service because of firewall issues.
Therefore I tried to find a solution to make it on my local computer possible.
What I did was the following steps :
- Search in the programs in the National Instruments directory the FPGA Compile tools and select the in my case firefox link.
- Once this is opened I was able to log on to the system using my pasword for adminstrator rights
- I selected the 2nd Icon and this gave me the message connecting... And not showing anything
- I opened the System web server (6th Icon) and changed the port that is normally blocked 3582 to port 8594 (I looked up the open ports of windows this is one of then)
- Changed the port number in the firefox link from the FPGA Compile tools and Reboot the computer.
- I started the FPGA Compile Worker and connected to the web configurator.
- In the 2nd Icon now I noticed that the I was able to get some information.
- Started up Labview and the FPGA compiler started building my code.
I don't know that this is a good way to do it. But this is the way I was able to compile my code locally when I could not connect to the Cloud Compile service.
Maybe this can be usefull for other people.
________________________________________________________________________
Problems will keep comming... Lets hope the answers do that to.
Never give up without a fight...
Message 31 of 31
(1,504 Views)
