Writing interleaved data into a TDMS uses a ton of memory
I'm trying to write a 500kb of boolean data to disk but the write takes a long time (72 seconds) and I run out of memory and get this error:
Error -2500 occurred at TDMS Write in TDMS write test.vi
Possible reason(s):
LabVIEW: (Hex 0xFFFFF63C) Storage VIs internal error.
Setup:
LV2018
sbRIO 9627
(2,347 Views)
I found these two articles which may be related to your issue:
http://digital.ni.com/public.nsf/allkb/8E57CA5AEB3D88B5862575B60063BA2A
https://www.ni.com/docs/en-US/bundle/labview/page/file-buffering-with-tdms-files.html
I hope this helps!
Megan T.
Technical Support Engineer
(2,321 Views)
The articles do not seem to be applicable because I'm not performing many small writes. It also doesn't explain the excessive memory use.
(2,317 Views)
