 choule
			choule
			08-09-2006 01:49 PM
08-10-2006 08:41 AM
Hello Chris,
Since you were careful to set the access domain, you should have permission to connect to the cRio. As an added test, you could set a star (*) as the access domain so the cRio will give everyone access (to make certain it isn't blocking you). Since you have ftp access, please check the ni-rt/system/www/ directory and make sure that there is an Index.htm as well as other web pages to test on. If there is no Index.htm in the www directory, then there really would not be a page to display. Http and the ip address should be all that is necessary to view the page if it has the Index.htm.
I hope this helps you.
Steven T.
