can't use CVIRTSup funtions at RTmain
Hello!I have a fully operational Real-time system with a host PC and a PCI target.I have wrote several programs which functioning perfecly(in CVI).So the problem is when i want to use the CVIRTSup fuctions like init(initialization) or read ,the compailer drops an error:undefinied function.I have the CVIRTSup dir. at the CVI folder have the header files ,so it's on my comp.I dont get it why i can't use any functions from this folder.If someone could write a few lines from a working code i would be thankful.(about shared memory useing at CVI).
Note tahat after hours of search i haven't find any usefull posts about Shared memory useing in CVI.Only a note that says:"Caution  This function makes a call to LoadLibrary. If you create a DLL that interfaces with CVIRTSup.dll, National Instruments recommends that you do not call this function from within DLLMain."
So it means i can't use any CVIRTSup functions at the RTmain source code?Than how can i use it?
(3,021 Views)
