crio 9074 cpu use
Hi Stephen,
That's really a good suggestion...I missed that memory pre-allocation! I will try to make the alterations and post you the result. Thank you!
João Barata
Message 11 of 12
(1,076 Views)
Hi Stephen,
I have already performed the changes you have suggested. Although a reduction of a few percent on the CPU charge of the CRio 9022 was noticed, in the CRio 9074 the code still doesn’t run @1KHz. I’m getting more and more convinced this isn’t a code problem, due to the following experience I'll briefly describe:
i) when running a single timed loop @1KHz in the CRio 9074, without any code inside it, the CPU charge is already about 25%.
ii) If you add code to read from the FPGA vi’s indicators (without actually showing the indicators), the CPU charge goes to about 50%...
iii)  when you add RT buffer write code the CPU charge goes up to 55%...and this is only with one timed while loop (no RT buffer read, no TCP connections to the PC!).
iv)  When adding the second timed  while loop code (@100Hz) for buffer read and TCP connections, the CPU charge goes to 80%...
v)    In this last situation, if you make the fpga and RT code to run automatically (without showing any front panel) the cpu charge lowers to 70%...so you only get around 30% to actually implement your code! If your controller isn’t very simple, you won’t get it to work!
Anyway, thank you for your help! Best regards,
João Barata
Message 12 of 12
(1,062 Views)
