data syncronization
Hi All,
Please find attached my excel file that shows results from a measurement with an optical powermeter and a voltmeter. I wrote two loop files in the same vi (I am very new in LabVIEW...). How can I synchronize the time? So both measurements are taking the same number of data points in the same time? Thank you!
(2,185 Views)
Accepted by topic author mulm
How are you acquiring the data?  What rate do you actually want?  What are the power meter and voltmeter models?  Could you share the code you have so far?
(2,171 Views)
Sorry for the late reply, I have seen now your message.
Many thanks, I have solved the problems meanwhile.
(2,071 Views)
