how do i make username and password access for my vi
How do make username and password access for mu vi
(5,570 Views)
If you want to just prevent somebody from accessing your VI, you can set a password by following these directions.
If you are asking how to setup a scheme for your VI where a user can gain certain permissions depending on their user name and password, you will need to setup a manual permissions handler in your VI. For example, you could have a lookup table with a set of known user names which links to a permission level string. Each time you want to run a VI, you can pass in the permission level string and handle it in the VI (e.g. case structure).
(5,482 Views)
