My signal source is floating, and i use SC-2345 for signal conditioning. On the box of SC-2345, it said "Always set E series board to NRSE mode when using the SC-2345 and SCC's". My DAQ board is PCI-6036E. So, does this mean i only can configure DAQ board as NRSE mode with Measurement and Automation Explorer?
Right now, i connected the accelerometer sensor output to the SCC-ICP01 module pin 1 and 2. It says 'pin 1 and 2 form a DIFF analog input channel for measuring the voltage across the ICP accelerometer'. Is my analog input signal connection correct? The user guide of SCC-ICP01 says 'for floating signal source in high-noise environments, connect the negative terminal of the signal so
urce to the AIGND terminal on the SC-2345 screw-terminal block to reduce the common-mode noise'. But i found AISENSE ,rather than AIGND terminal there. Are they same? If not, where can i find it?
Thanks a lot!
