06-30-2005 11:05 AM
07-07-2005 05:24 PM
Hi, Fringe,
You are correct, IMAQ works under LabVIEW Real-Time, however the Real-Time 7.1 platform currently does not support PCI Express boards. That is probably the reason why you are getting all of those crashes after installing the IMAQ driver. The engine might be trying to identify the card, but since PCIe is not compatible with RT, that could be generating the errors.
I hope this helps.
GValdes
05-01-2006 03:46 PM
05-02-2006 06:53 PM
Carlson,
"So what you are saying is that the PCIe-1429 board I bought for my RT computer to capture images from a 1000 fps camera is not going to work in RT OS?"
That is correct.
Lorne Hengst
Application Engineer
05-28-2009 04:37 AM
I am having a very similar problem, where my system randomly reboots
I am running LabVIEW RT 8.6.1with
-Dell PC With Dual Quad core (8 cores total), 2GB memory
-NI PCIe 1430 Frame Grabber with NI Camera Link I/O Extension Board (used for encoder input)
-NI Vision RT 8.6.1
-NI-IMAQ RT 4.1.0
-NI-IMAQ Server 2.6
Sometimes the system can run up to 8 hours straight and other times only 30 minutes.
All I get on the screen after reboot is this message: "Reboot due to system error."
Every time the system reboots a new entry is added to the rtlog.txt, all similar logs (Below is one example)
Any suggestions or help will be much appreciated.
Thank you,
Octavian C.
Below is the rtlog.txt
*** BEGIN SYSTEM EXCEPTION LOG ***
Target type: Generic Desktop PC
Target code: 719C
System time (UTC): 2009-05-28 09:02:05
System tick count: 51001398 ms
Exception code: 0x80000003
Register contents:
EAX = 0x0000000A  EBX = 0x7EC81A10  ECX = 0x00000000
EDX = 0x7ED7E5AC  ESI = 0x00000001  EDI = 0x00000000
EBP = 0x07C53A44  ESP = 0x07C53A38  EIP = 0x0011ED61
CS = 0x0018  DS = 0x0020  SS = 0x150020
ES = 0x0020  FS = 0x6180028  GS = 0x100020
Thread name: LabVIEW Execution System 2 Thread 1
Thread stack base: 0x07C34000  stack size: 131072
Call Stack:
Level  1:  Code pointer: 0x0011ED61  Stack Base: 0x07C53A44
Level  2:  Code pointer: 0x06948D04  Stack Base: 0x07C53A7C
Level  3:  Code pointer: 0x06948D11  Stack Base: 0x07C53CB4
Level  4:  Code pointer: 0x06651E8C  Stack Base: 0x07C53CD0
Level  5:  Code pointer: 0x067A039D  Stack Base: 0x07C53E14
Level  6:  Code pointer: 0x065DFBF7  Stack Base: 0x07C53E38
Level  7:  Code pointer: 0x065DD7BA  Stack Base: 0x07C53F8C
Level  8:  Code pointer: 0x065DDB7A  Stack Base: 0x07C53FA0
Level  9:  Code pointer: 0x067B3118  Stack Base: 0x07C53FB0
Level 10:  Code pointer: 0x00101A48  Stack Base: 0x07C53FE4
Level 11:  Code pointer: 0x001078B4  Stack Base: 0x00000000
Loaded Modules:
00100000-002629AF PH_EXEC_SMP.EXE (C:\PH_EXEC_SMP.EXE) 2008-12-17 17:44:58
06450000-06454FFF WSOCK32.dll (C:\ni-rt\system\WSOCK32.dll) 2008-12-17 17:52:50
06456000-064A3FFF i8254x.dll (C:\ni-rt\system\ethernet\i8254x.dll) 2008-05-27 18:36:41
06442000-0644DFFF ftpserve.dll (C:\ni-rt\system\ftpserve.dll) 2008-10-08 19:14:48
06564000-0656AFFF emblview.exe (C:\ni-rt\system\emblview.exe) 2007-11-27 22:15:37
0656C000-06926FFF lvrt.dll (C:\ni-rt\system\lvrt.dll) 2008-12-10 19:41:37
06928000-0693EFFF LIBEXPAT.dll (C:\ni-rt\system\LIBEXPAT.dll) 2008-09-24 21:05:50
06940000-06995FFF MSVCR71.dll (C:\ni-rt\system\MSVCR71.dll) 2003-02-21 12:42:20
06997000-06A11FFF MSVCP71.dll (C:\ni-rt\system\MSVCP71.dll) 2003-03-19 04:14:51
06A45000-06AC9FFF lvuste.dll (C:\ni-rt\system\lvuste.dll) 2008-12-17 17:37:14
06C9E000-06CB6FFF tsengine.dll (C:\ni-rt\system\tsengine.dll) 2007-03-05 15:53:36
06CB8000-06CBDFFF nisl_emb.dll (C:\ni-rt\system\nisl_emb.dll) 2007-08-22 18:19:38
06CBF000-06CC6FFF nisvcloc.dll (C:\ni-rt\system\nisvcloc.dll) 2008-04-24 20:32:15
06D63000-06D76FFF VESA.dll (c:\ni-rt\system\VESA.dll) 2008-06-24 04:26:47
06DA5000-071F4FFF nivision.dll (c:\ni-rt\system\nivision.dll) 2008-08-07 22:52:12
071F6000-07205FFF nirpc.dll (C:\ni-rt\system\nirpc.dll) 2008-06-13 14:50:09
07207000-076AAFFF nivissvc.dll (C:\ni-rt\system\nivissvc.dll) 2008-08-07 22:48:18
06D78000-06D7EFFF nivismgr.dll (C:\ni-rt\system\nivismgr.dll) 2008-08-07 22:47:34
076AC000-076B8FFF tbbmalloc.dll (C:\ni-rt\system\tbbmalloc.dll) 2007-09-20 18:02:21
076BA000-076E6FFF nivisemb.dll (C:\ni-rt\system\nivisemb.dll) 2008-08-07 22:47:28
076E8000-0784CFFF imaq.dll (c:\ni-rt\system\imaq.dll) 2008-06-26 21:41:55
0784E000-078B4FFF NIPALP.dll (C:\ni-rt\system\NIPALP.dll) 2008-12-15 23:36:54
0644F000-0644FDBF nipalpg.dll (C:\ni-rt\system\nipalpg.dll) 2007-05-17 21:35:07
078B6000-078F4FFF niimaqk.dll (C:\ni-rt\system\niimaqk.dll) 2008-06-26 21:37:27
078F6000-07900FFF registry.dll (C:\ni-rt\system\registry.dll) 2007-08-20 21:45:34
07B6E000-07BA8FFF imaqcfgs.dll (c:\ni-rt\system\imaqcfgs.dll) 2008-06-23 18:05:35
07BCB000-07BFFFFF lvalarms.dll (C:\ni-rt\system\lvalarms.dll) 2008-12-17 17:38:17
0804B000-081E4FFF lvanlys.dll (C:\ni-rt\system\lvanlys.dll) 2008-04-09 05:43:47
08024000-0802DFFF nbfifo.dll (C:\ni-rt\system\nbfifo.dll) 2008-12-01 22:41:36
0803A000-0803FFFF settime.dll (C:\ni-rt\system\settime.dll) 2007-12-03 19:05:50
Memory statistics:
Total system memory:           2137041920 bytes
Free memory:                   1866101376 bytes
Largest free block:            1859973072 bytes
Free RTOS heap memory:         9888 bytes
Largest free RTOS heap block:  2048 bytes
*** END SYSTEM EXCEPTION LOG ***
