SAPHIR - Toolkits Discussions
GModbus over Serial Line Activation Issues
I need to activate the "GModbus Over Serial Line" on a new PC. The activation wizard in LabView can't activate the toolkit with the activation keys I received with the order. I also can't generate a new key on the NI website, because according to NI "this product can no longer be activated".
Can someone tell me, how I can activate the package, because I really need Mosbus communication for a laboratory and the 14 day trial just expired.
Kind regards.
Message 1 of 10
(5,421 Views)
Accepted by MOSick
Our toolkit are not sold anymore on LVTN since 01 nov 2022...
However we still support licences bought before this date.
We should push our toolkits on open source repo one day 🙂
This topic has been resolved directly with  MOSick by pm
Christophe | Armatan | Certified LabVIEW Architect
Message 2 of 10
(5,391 Views)
Hi Christophe
Any idea when you'll be able to open source the ModBus products?
I might need a ModBus TCP soon, it would be great to use GModBus over TCP as open source!
Cheers
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 3 of 10
(5,368 Views)
Hi Antoine,
No idea about a release date, this is not a priority topic.
However, you can still contact us, and we will share you a copy of the source code
Message 4 of 10
(5,353 Views)
I also need to need to get a copy of saphir GModBus over serial line onto a new PC. I have a license on my old PC. Is there anyway that I can transfer the license to a different PC?
or
Can I also have access to the source code?
john
Message 5 of 10
(5,320 Views)
Hi
This is not possible to transfert a licence anymore.
I sent a download link by private message
Message 6 of 10
(5,303 Views)
Hi Christophe,
I am currently experiencing the same issue that was discussed in this discussion board. Our company previously purchased the license for the GModbus over TCP & Serial toolkits from NI, I can provide you with the part number and serial number if you want to verify our purchase. I noticed that you offered others an opportunity to temporarily download the source code and I was wondering if you could potentially offer me the same opportunity as well? Any assistance or response that you could provide would be most helpful. Thanks.
Message 7 of 10
(4,857 Views)
Hi Javier,
Since the last message, we have migrated the source code of our toolkits on gitlab as open source projets.
You can find them on https://gitlab.com/QMT-group/open-source
You can either use the source code on your project and relink the VIs, or try to install the vip file that has been rebuild without licence activation (at your own risk, it has not been tested and verified yet => please let me know if you test it)
Message 8 of 10
(4,852 Views)
I am having similar issues in that I have been using this tool for a decade now and had to rehost all my vi's on the new PC and now all of my GModbus vi's are broken.  I tried installing the tool from the site above but they are all still broken and it states the root cause is due to broken dependencies.
Message 9 of 10
(4,296 Views)
I ran into a similar issue when I tried to install the VIs. I had to disconnect a few type defs and make copies that allowed me to decouple the VIs I needed.
Message 10 of 10
(4,280 Views)
