Signal Conditioning
CRC-4 calculation for SENT- Interface
i have a SENT- Signal and try to create a VI which is calculate the CRC-4. I did not make it. The polynom is x4+x3+x2+1 and the seed value is 0101. I need a VI which is calculate the CRC-4 for the SENT- Signal.
Maybe someone can help me?
Best regards
Sebastian
(7,901 Views)
Do you have examples of inputs and expected outputs?  There are many variations on CRCs and it is hard to get it figured out without some test data.
GCentral
(7,895 Views)
Hey Sebastian,
you dont need to write the CRC check by yourself. This is already done and can be found here:
SENT Driver API - National Instruments - National Instruments
https://www.ni.com/en/support/downloads/tools-network/download.sent-driver-api.html
Community: SENT Communication Protocol Reference Example in LabVIEW FPGA - National Instruments
https://forums.ni.com/t5/Example-Code/SENT-Communication-Protocol-Reference-Example-in-LabVIEW-FPGA/...
Both examples include a VI for the CRC check.
Regards, Stephan
(7,880 Views)
