Signal Conditioning
Do I need to configure something different,when I'm using SCXI-1000,1102 and 1180, together.?
I am wanting to use SCXI-1000 with 2 modules SCXI-1102, but I also want to access the DAQ (ni pci 6035), through the SCXI-1180, to access some Digital I/O. How can I do that? What cable type between the SCXI and DAQ (6035) do I need to use? Do I need to configure something different? When I only configure the SCXI-1000 and SCXI-1102, I use the cable with 68 pins in both extremities and I don't have problems. But when inserting SCXI-1180, a following error message it is generated:
"Dev1" digital lines 0, 1, 2 & 4 are in use by the connected SCXI subsystem.
It happens when observing DIGITAL I/O in Test Panel in M A X.
thanks
Brás
(3,633 Views)
Hello Bras,
I think the following article will explain why you are receiving the error message. Digital lines 0, 1, 2, and 4 are actually used for SCXI communication.
http://digital.ni.com/public.nsf/websearch/5979CA0B55AEB7E78625656800599623?OpenDocument
Take care,
E.Lee
Eric
DE For Life!
(3,626 Views)
Thanks for the information! The examples sent me, were useful, but always I use Digital functions, just after I can't perform tests with SCXI, it doesn't respond, it becomes inactive until I reset Traditional NI-DAQ Devices.What can I do to have the VI attached running well? Can you help me?
thanks
José Brás
(3,584 Views)
Hello Jose Bras,
The reason that you need to reset the Traditional NI-DAQ Devices is because you are using two different drivers in the same program, Traditional and DAQmx. Your Digital Writes/Reads are done using Traditional DAQ but your SCXI code is done in DAQmx. I would recommend that you use DAQmx to program your Writes/Reads.
Take care,
E.Lee
Eric
DE For Life!
(3,568 Views)
