Signal Conditioning
How we can detect the open Thermocouples
I need to check for open end in thermocouple. I wanted to know if the SCXI-1125 itself checks for the open end?, and how can i know that a thermocouple is open ended.?
(3,792 Views)
You will read something like 275 degrees centigrade.
Ole
(3,786 Views)
Ole
Most front-circuits for thermocouples I have seen have the feature of detecting an open thermocouple. Usually a small amount of current is fed across the thermocouple, and since its dc impedance is rather low a small current will cause only minor output voltage error, If the thermocouple is open the impedance is inf., and the small current across the open thermocouple will cause a rather high input voltage. The signal conditioning circuitry will read a temperature which is out of reasonable range.
(3,780 Views)
Please refer to this KnowledgeBase. This discusses open thermocouple detection, and which SCXI boards support it. I hope this helps and have a Great Day!
Best Regards,
George
(3,776 Views)
Gajanan
(3,771 Views)
