 Imran Malek
			Imran Malek
			02-27-2008 09:19 AM
 JB
			JB
			02-27-2008 10:24 AM - edited 02-27-2008 10:30 AM
02-27-2008 10:55 AM
Thanks JB for the prompt reply, I will try to get my hands on an appropriate amplifier and then report my findings here!
Thanks again
 Brooks_C
			Brooks_C
		02-28-2008
		02:38 PM
 - last edited on
		05-15-2024
		09:43 AM
 by
		 Content Cleaner
			Content Cleaner
JB is correct; the BNC-2120 is not made to directly make load cell measurements. You may want to consider getting a SCC-68 with an SCC-SG24 module (The SCC-SG24 provides 10V excitation, but we have other SCC-SG0X modules for other bridge configurations). This setup will provide the excitation voltage and allow you to make the measurement you want. The reason you need to apply the excitation voltage is because load cells are really just resistors. The excitation voltage is applied to the load cell resistor bridge and then the measured output voltage is proportional to the excitation voltage--without this excitation it’s difficult to predict what you will read, but it won't be the correct value. If you’d like to speak with a technical representative about getting these signal conditioning modules you can contact National Instruments directly at www.ni.com/contact.
I believe that the load cell you are using has the full bridge internally so it is possible that you could used this with your current setup, but as JB said, the signals you’re measuring are very small so the SCC modules would be the preferred method for obtaining accurate measurements. The 6221 has a +5 volt pin that you could use as the excitation voltage for your bridge, but you’d have to configure the measurement as a voltage task and do all of the analysis in software to convert the voltage to a strain measurement taking into account the excitation voltage. You can try that out and see if it meets your needs, but otherwise I’d suggest looking into the signal conditioning options since they will provide much better results.
I hope this helps, and have a great afternoon!
09-10-2008 09:38 AM
Hi guys!
Im borrowing this tread a little. I have a customer that uses a PCI6251+ BNC2120 to get an input signal to his computer. He puts a 3V input DC gain and records the signal to his harddrive, but the recorded signal only shows 0.01V. Do anybody have an idea what the problem might be?
Bjorn
