Signal Conditioning
SCXI1200 not shown in create new list
I am trying to re-install SCXI 1000 chassis with a 1200 board. I do not show a scxi-1200 from the create new list. I can install a 1000 chassis, but when I try to install the 1200 from there is does not allow me. This is Labview 6.1
Steve
Message 1 of 8
(4,388 Views)
Just to close the loop . . .
Ayman in tech support was able to answer this. Even though it was win2k, basically I had to add the 1200 from Add Windows Hardware in the Control Panel. (I was led to believe you only did that in Win98.)
Message 2 of 8
(4,380 Views)
Hello Steve,
Please follow the steps in this KB: http://digital.ni.com/public.nsf/websearch/334BA1D8691AD25486256539004CC1A8?OpenDocument
What version of NI-DAQ are you using? Also, what OS are you using? The SCXI-1200 is not supported past NI-DAQ 6.9.3, and only on Windows 95/98/2000/NT.
I hope this helps,
Sean C.
Message 3 of 8
(4,374 Views)
I am also having this problem with the scxi-1200. Can the earlier version of ni-dag be used with labview 7?
Steve
Message 4 of 8
(4,376 Views)
Hi Mike,
As Sean pointed out the NI-DAQ 6.9 is the last version NI-DAQ that supported the 1200.
Labview 7 provides Traditional NI-DAQ for some older equipment, but the 1200 will not work with the Traditional NI-DAQ.
So if you have a 1200, basically you should upgrade to a 1600 for use with Labview 7 is what I have been led to understand. (I'm still using Labview 6.1 w/win2k, but also upgraded to 7.1 and bought a 1600 and will upgrade my app when I get the chance.)
Hope that's clear 😉
Steve D.
Message 5 of 8
(4,366 Views)
Hi Mike,
You actually can use NI-DAQ 6.9.3 with LabVIEW 7.x. Please see the following Knowledge Base for instructions on how to install this.
http://digital.ni.com/public.nsf/websearch/F185E098C7EC5A3486256D2E00691BB2?OpenDocument
Let me know if you have anymore questions.
Sean C.
Message 6 of 8
(4,356 Views)
@Sean C. wrote:
Hi Mike,
Sean C.
Sorry, I scrambled that particular combination. Is it that the 1600 won't work with NI-DAQ 6.9.3?
Steve D.
Message 7 of 8
(4,349 Views)
Hi Steve,
That's correct. The SCXI-1600 is not supported until NI-DAQ 7.2, and then only in DAQmx.
Sean C.
Message 8 of 8
(4,333 Views)
