Signal Conditioning
SENT Interface - Data nibble connection
maybe someone can help me. My problem is that i don't know, how can i connect 3 nibbles (any 4bit) values (ticks (decimal), not binär values) to a 12bit value in decimal unit? Here a short example: 1st nibble: 3 (decimal, 4bit); 2st nibble: 10 (decimal, 4bit) and the third nibble: 8 (decimal, 4bit). Actually, this three nibbles should be one data-value in decimal unit. How is the relation? How can i combine the single nibbles to one value? For a Example for a SENT-signal look at the attachments.
Thanks for help and best regards,
Sebastian
Message 1 of 8
(6,991 Views)
Not sure want you exactly want. Maybe something like this ?
Kees
Message 2 of 8
(6,979 Views)
thanks for your fast response. Unfortunally, i can not open your VI because i only have the Labview 2013 version. Maybe you can convert the VI?
Best regards
Sebastian
Message 3 of 8
(6,962 Views)
Accepted by blackhack999
In LV 2013
Kees
Message 4 of 8
(6,955 Views)
Thank you. This is the solution.
Best regards
Sebastian
Message 5 of 8
(6,949 Views)
could you please provide nibble.vi also  for LV2012?
thank you in advance
Elena
Message 6 of 8
(6,554 Views)
And in LV 2012
Message 7 of 8
(6,540 Views)
Thank you very much
best regards,
Elena
Message 8 of 8
(6,538 Views)
