Signal Conditioning
how to realize More channels 4-20mA current loop output
Dear Sirs,
I have a question,we have a 4-20mA input,4-20mA out,24V power product,but my client need two 4-20ma output at the same time ,and on a broad.pls someone tell me the circuit.Thanks.
Cheers!
Candy
Message 1 of 17
(10,630 Views)
http://en.wikipedia.org/wiki/Current_mirror
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 17
(10,617 Views)
   With an analogue data transmitter module from TURCK you can solve your application.
   Take two IM31-11-i modules from TURCK. Connect the 4-20mA output of the 1st module,
to the 2nd module, so you feed the current trough both modules. Then your original 4-20mA
is found at the output of both module 1 and 2.
   Here is the TURCK Website:  http://www.turck.de/en/
________________________________________________________________________________________________________
http://www.industrial-automation-hands-on.com/
Message Edited by frank_h on 10-29-2008 07:49 AM
Message 3 of 17
(10,567 Views)
..and if you want to feed more then one input you can also put two or more inputs in series. As long as the total resistance is not higher then specified by your source.
Message 4 of 17
(10,546 Views)
Thanks.now i design a two output circuit: Pls check it,and see whether it is right.
Message 5 of 17
(10,535 Views)
Hi Candy,
It is almost right, I think. Why the diodes at the inputs.
When I look at the datasheet of your isolator (I only can read the figures not the characters Smiley Wink ) the input is 50Ohm. So the input voltage (across the diode) is 0.2-1V. The 1N4007 starts to conduct at 0.6V.
Message Edited by K C on 10-31-2008 08:26 AM
Message 6 of 17
(10,527 Views)
Thanks,KC. our this series input resistance is 50 ohm(max),when 4-20ma signal input,the input voltage across the diode is 10mV~50mV. Cheers! Ms. Candy
Message 7 of 17
(10,505 Views)
Dear Sir, sorry,i have another question,still about 4-20ma signal,can supply power to two wires sensors.but its accuracy is so low,only 0.3%~0.4%, but generally need 0.2%.we are thinking of many ways,but still have no effect.
Message 8 of 17
(10,502 Views)
Hi Candy,
According to Ohm's law (at least at this side of the world Smiley Wink ) a current of 4-20mA through a 50Ohm resistor gives a voltage of 0.2 - 1V
Please explain your value of 10-50mV
I do not understand your second question. A accuracy of 0.3-0.4% is rather good I think for transmitters.
Message Edited by K C on 11-03-2008 08:34 AM
Message 9 of 17
(10,484 Views)
Accepted by Candy Yu
Message 10 of 17
(10,478 Views)
