Signal Conditioning
input voltage limits for the scc ft01 module
what is the maximum amplitude of input voltage that i can supply to the scc ft01 module?
(3,594 Views)
The SCC-FT01 passes the signal directly back to the connected MIO. Limit its input voltage to the specification of your DAQ board.
Charles
(3,581 Views)
For example, most of our E series and M series DAQ boards have a voltage range of + or - 10 V. If you put more or less voltage than that, you will damage the board.
Anuj D.
(3,561 Views)
