Signal Conditioning
peak detection in C
Hi All,
I am looking at implementing or using the peak detection function in C. I require the same in C since, I would be later porting this application on microcontroller.
However, the function implemented in LabVIEW calls the lvanlys.dll for performing the peak or valley detection. Hence, I would not be in position to use the same and later port it on the controller.
Essentially I am looking for similar function inputs (threshold and width) implemented in C.
Thanks in advance.
Regards.
(7,643 Views)
http://www.nr.com/
http://en.wikipedia.org/wiki/Numerical_Recipes
Numerical Recipes in C. The Art of Scientific Computing, 2nd Edition, 1992, ISBN 0-521-43108-5.
Greetings from Germany
Henrik
LV since v3.1
(7,637 Views)
Thanks Henrik Volkers for sharing the link
Shall refer to the book and extract the necessary function.
The book also contains implementation of various other functions.
Regards.
(7,626 Views)
