Signal Generators
Chirp Signal Using NI-FGEN Arbitrary Waveform Mode
I have a function generator NI PXI 5412. I need to generate a Chirp signal (not swept sine) where the frequency linearly increases in the signal.  I have created the chirp signal by updating the LabVIEW example "Fgen Arbitrary Waveform.vi". The program can generate chirp signal properly.
But, the chirp signal repeats itself after finishing the sweep.  It can only be stopped manually by clicking the stop button.  I need to run the Chirp signal only once.   The total number of samples and total time for one chirp sweep are known.
How can I stop the program automatically after one run?  I have attached the code for chirp signal generation.
(5,035 Views)
Accepted by a_haque
Continuous is the default Trigger Mode is on most NI Fgen devices. This means the signal wraps around and continues to play from the beginning until you tell it to stop. If you only want it to output once, use single trigger mode: http://zone.ni.com/reference/en-XX/help/370524P-01/siggenhelp/5412_smc_single_trigger/
http://zone.ni.com/reference/en-XX/help/370524P-01/nifgenlv/nifgen_configure_trigger_mode/
Brian Morgan | NI Software Engineer, R&D
(5,018 Views)
Hi Brian,
Thanks for the suggestion.  It works.
(5,011 Views)
