11-19-2009 06:15 PM
11-20-2009 12:56 PM - edited 11-20-2009 12:57 PM
The cRIO 9004 is a controller and is not a data acquistion device.
If you have a cRIO module for data acquisition, you would be using the DAQmx driver and look at the example programs that get installed for whatever language you are using.
p.s. Further questions should be posted to a more appropriate board (i.e. Multifunction DAQ). You do not have a NI Signal Generator.
11-23-2009 11:08 AM
Dennis, the DAQmx driver is not compatable with a cRIO. We need to use the NI RIO driver to get data from the modules using Scan Mode or custom FPGA and Real Time code.
There are module Specific exmaples for each module in the NI Example Finder (Help»Find Examples) (Hardware Input and Output»CompactRIO»Module Specific)
