SignalExpress
Craches during start up
Hi
When I try to start my Signal Express 3.0, the splash screen just apere for a second then windows will stopp it.
I´m using Vista 32bit
Message 1 of 10
(10,295 Views)
My first suggestion would be to try doing a "Repair" on the SignalExpress installation; under Start >> Control Panel >> Programs and Features >> National Instruments Software, select NI LabVIEW SignalExpress 3.0 and press the Repair button.
If that does not work, perhaps you could tell me some of the following:
1. Did you upgrade SignalExpress from a previous version?
2. Did you only install SignalExpress recently, or also other NI software?
Phil
Message 2 of 10
(10,289 Views)
Also, can you provide more information about what happens?  Does SignalExpress or Windows provide any message when this occurs?  Was the product installed from an administrator account?  What type of account are you trying to access SignalExpress from?
Message 3 of 10
(10,285 Views)
Accepted by Åland
I found a sulution... When I disable the "UAC" control in user acount conrol panel the SignalExpress works. Don't realy know if it's nessesery to have UAC activated.
Message 4 of 10
(10,230 Views)
Hi Aland,
Great to know that you got it to work. However, SignalExpress will work without disabling UAC. We specifically test for it and there are numerous users who have been working with SignalExpress since release with UAC enabled. There could be something else that's causing this problem. The above mentioned questions might help us find the cause. It definitely would be great if we could continue this conversation. Thank you.
Message 5 of 10
(10,194 Views)
Found out just now that if UAC is disabled the DAQ Assistant in Labview 8.6 stops during initialization and I have to restart LV again. I tried to repair Signal Express, and reinstalled NI-DAQmx 8.7.2. Still same problem. My installed LV 8.5 works, no matter if UAC is disabled or not.
Message 6 of 10
(10,012 Views)
I have same problem, for over a year it was working fine, now just crashng at start-up. I'm using Windows XP SP3. The error sound like this:
 "LabVIEW SignalExpress has encountered a problem and needs to close.  We are sorry for the inconvenience."
 error signature:
AppName: signalexpress.exe     AppVer: 3.0.0.3000     ModName: kernel32.dll
ModVer: 5.1.2600.5781     Offset: 00012afb
LOCALS~1\Temp\NI_ERRORLOG.TXT caused an Unknown exception type (0xe0434f4d)
in module kernel32.dll at 001b:7c812afb.
Exception handler called in Unhandled exception.
C:\Program Files\National Instruments\SignalExpress\SignalExpress.exe
Operating system:  Windows XP (5.1.2600).
2 processor(s), type 586.
30% memory in use.
Context:
EDI:    0x00204a10  ESI: 0x09e0e8a4  EAX:   0x09e0e818
EBX:    0xe0434f4d  ECX: 0x00000000  EDX:   0x0000012f
EIP:    0x7c812afb  EBP: 0x09e0e868  SegCs: 0x0000001b
EFlags: 0x00000202  ESP: 0x09e0e814  SegSs: 0x00000023
Bytes at CS:EIP:
5e c9 c2 10 00 85 ff 0f 8e 36 93 ff ff 8b 55 fc
 Module 1
Image Base: 0x00400000  Image Size: 0x00087000
Checksum:   0x000737b3  Time Stamp: 0x48480af3
File Size:  536576      File Time:  6/5/2008 11:07:20
Version Information:
   Company:    National Instruments
   Product:    LabVIEW SignalExpress
   FileDesc:   LabVIEW SignalExpress
   FileVer:    3.0.0.3000
   ProdVer:    3.0.0.3000
I tried to repair still the same problem, i also restored m computer toan earlier restore pont, still the same problem...
Message Edited by John_UMF on 05-19-2009 01:54 PM
Message 7 of 10
(9,524 Views)
 Could be a problem that I exchanged 2 drive letters between them (none of them with installed LabView)?
Message Edited by John_UMF on 05-19-2009 02:18 PM
Message 8 of 10
(9,518 Views)
Now, not even Measurement & Automation explorer doesn't work... same error, crashing at start
Message 9 of 10
(9,508 Views)
I unistalled and reistalled the whole LabView software, cleaned the registers and no change. I get the same error. LabView 8.6 work fine instead. What can i do? I don't want to format my hard drive...
Message 10 of 10
(9,493 Views)
