To measure frequency with SignalExpress using your USB-6501
Add a DAQmx Acquire->Analog Input step, put your digital input into the analog input you pick, set the sampling rate to be atleast 2-10x the input signal rate.
Add the Timing and Transition step
Run the VI
Observe the frequency.
MatthewW Applications Engineer National Instruments
