07-20-2011 08:20 AM
Hi all,
I need to take data from LVDT sensors over a long period of time (18 hrs), and I would only like to take one reading per second, yet every time I try to change the frequency and run the DAQ I get an error saying that my frequency is not in the accepted range. What's causing this? And how can I fix it?
07-20-2011 10:18 AM
What hardware are you running?
I'm not able to duplicate the error on my end. I've set Samples to Read=1 and Rate=1. With those settings I'm sampling 1 data point per second.
A copy of your .seproj file may be helpful as well.
07-20-2011 10:38 AM
Actually, I just figured it out. I'm new to using signal express and hadn't adjusted the "Samples to read" area. It's now working as planned. Thanks!
