SignalExpress
Need to take data over a long period of time (18 hours) from LVDT sensors, getting an error?
Hi all,
I need to take data from LVDT sensors over a long period of time (18 hrs), and I would only like to take one reading per second, yet every time I try to change the frequency and run the DAQ I get an error saying that my frequency is not in the accepted range. What's causing this? And how can I fix it?
(5,765 Views)
What hardware are you running?
I'm not able to duplicate the error on my end. I've set Samples to Read=1 and Rate=1. With those settings I'm sampling 1 data point per second.
A copy of your .seproj file may be helpful as well.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,759 Views)
Actually, I just figured it out. I'm new to using signal express and hadn't adjusted the "Samples to read" area. It's now working as planned. Thanks!
(5,757 Views)
