SignalExpress
signal express crash
I have this problem, for over a year it was working fine, now just crashing at start-up. I'm using Windows XP SP3. The error sound like this:
 "LabVIEW SignalExpress has encountered a problem and needs to close.  We are sorry for the inconvenience."
 error signature:
AppName: signalexpress.exe     AppVer: 3.0.0.3000     ModName: kernel32.dll
ModVer: 5.1.2600.5781     Offset: 00012afb
LOCALS~1\Temp\NI_ERRORLOG.TXT caused an Unknown exception type (0xe0434f4d)
in module kernel32.dll at 001b:7c812afb.
Exception handler called in Unhandled exception.
C:\Program Files\National Instruments\SignalExpress\SignalExpress.exe
Operating system:  Windows XP (5.1.2600).
2 processor(s), type 586.
30% memory in use.
Context:
EDI:    0x00204a10  ESI: 0x09e0e8a4  EAX:   0x09e0e818
EBX:    0xe0434f4d  ECX: 0x00000000  EDX:   0x0000012f
EIP:    0x7c812afb  EBP: 0x09e0e868  SegCs: 0x0000001b
EFlags: 0x00000202  ESP: 0x09e0e814  SegSs: 0x00000023
Bytes at CS:EIP:
5e c9 c2 10 00 85 ff 0f 8e 36 93 ff ff 8b 55 fc
 Module 1
Image Base: 0x00400000  Image Size: 0x00087000
Checksum:   0x000737b3  Time Stamp: 0x48480af3
File Size:  536576      File Time:  6/5/2008 11:07:20
Version Information:
   Company:    National Instruments
   Product:    LabVIEW SignalExpress
   FileDesc:   LabVIEW SignalExpress
   FileVer:    3.0.0.3000
   ProdVer:    3.0.0.3000
I tried to repair still the same problem, i also restored my computer to an earlier restore point, still the same problem...
I moved entire MAX directory to desktop, no result...
Now, not even Measurement & Automation Explorer doesn't work... same error, crashing at start
I unistalled and reinstalled the whole LabView software, cleaned the registers and no change. I get the same error. LabView 8.6 work fine instead. What can i do? I don't want to format my hard drive...
(9,445 Views)
Accepted by John_UMF
Unfortunately formating was ultimate solution. That did it. Only the OS partition was formatted and reinstalled.
Now it's fully working.
I think the problem was with a software which deactivated the administrator rights (as I saw the same problem with user rights in Vista OS) .
So , it's solved! (kind of...).
(9,402 Views)
Dear John,
so do I.
I have the same problem in the Signal Express 3.0 (limited edition) under Windows XP SP2 for my DAQ 6008-USB. The software runs fine until this past Friday, when I introduced the license code. From this moment, the software crashed all the time and an informative message advice me the same than you (Signal Express detected a problem and it has to be closed).
I reinstalled the Signal Express twice, and after the second reinstallation (maybe license code was deleted this last time) Signal Express worked OK. In order to discard options, I reintroduced the license code, AND THE PROBLEM REAPPEARED!
I would like if in your case, you also introduced your license before your problems started.
Juan Pablo RODRÍGUEZ
(9,025 Views)
Well, the problem appeared after the program worked fine for over 6 month with licence code installed. I installed another software wich altered some user files and limited acces to administrator only and that make my signal express to crash...
(9,009 Views)
humm... Very interesting. Did you try to let the first program unaltered? In your case, the problem could come from some conflict between original software and the after-installed software.
In my case, the problem appeared inmediatelly after installing the license code. Yesterday I tried to contact with Sales person in charge of Barcelona area in order to find some solutions, but he is out of the office.
when I had a clear answer I will forward to you, may be it can be useful for you.
Many thanks for your quick answer John.
Juan Pablo RODRIGUEZ
(9,004 Views)
