Switch Hardware and Software
PXI-2570
Does the NI-Switch 2.1 support the PXI-2570?
I allways become the Error -1074135030 when trying to acess my device through the NI-Switch vis.
(6,600 Views)
You should be able to use NI-SWITCH 2.1 with the PXI-2570. You could always update the driver to the newest version NI-SWITCH 3.0
What is the function that is giving you the error? Are you able to open the soft front panel?
Guy Ferraro
NI - USA
(6,597 Views)
