Switch Hardware and Software
What's the SAMTEC part number for J1 on TB-264x column connection board 191682B
It the 66 pin right angle connector that plugs into J1 (SAMTEC FLE-137-01-G-DV-P-TR) on the Module Interface Board (192834 on the TB-2642).  It's 2 row 39 position with only 33 position filled so it must be a semi custom part?
Darrow
(6,813 Views)
Hi Darrow,
It is a FSH 39 pin shrouded terminal strip, with only 33 pins populated. The base part number is  FSH-39-D-ES-35, and it is a semi custom part. Are you trying to make your own custom connections?
Matt
Applications Engineer
(6,800 Views)
Accepted by Darrow
Yes, I'm replacing the column board with something like this...
21441iEB65F18CE58AAAD3
(6,793 Views)
Hey Darrow,
Are you familiar with the PXI-2531, which uses VHDCI connectors as breakouts instead of ribbon cables?
This module is similar to the PXI-2532, but is only rated to 60VDC and doesn't support as many topologies as the 2532.  See the specification sheet for more info.
This would prevent the design of such a cable.
If you do go through with the custom cable, make sure you provide sufficient strain relief.
John Sullivan
Switch Product Support Engineer
-John Sullivan
Problem Solver
(6,766 Views)
