The Daily CLAD
Community Browser
Re: Design Patterns: Multiple Loops
SercoSteveB
Active Participant
Which of the following are reasons for using a multiple loop design pattern?
a) Execute multiple tasks concurrently
b) Execute different states in a state machine
c) Execute tasks at different rates
d) Execute start up code, main loop, and shutdown code
https://decibel.ni.com/content/docs/DOC-21613
Comments
crossrulz
Knight of NI
A & C
mini09
Active Participant
A, I have a confusion in option C. If we have multiple loop at different rate of delays will it not affect the entire program delay?
LordNobady
A and C
@gnshmrthy
If you place the loops in paralel then the program length is the time the longest loop is running.
Common things to do in paralel are:
- Interfacing ( users, devices, databases, files )
- Programing logic ( calculations, desisions )
depening on requierments there can be multipe loops for every one of these. A commom usage case is the producer consumer.
Learning LabVIEW since January 2013
crossrulz
Knight of NI
Have you heard of Multicore?  Well, it actually comes down to multi-threading.  A thread is a single process that runs as its own little program.  So what happens when you have multiple loops with no data dependency?  LabVIEW turns each parallel process into its own thread.  So the loops do not affect each other other than possibly the communication scheme.  And with multi-core, you can have different threads truely run at the same time.
MrStevenUND
A & C.
BPerlman
A & C
Ihab
A
ljbandres
A & C
edgar01
A and C
SercoSteveB
Active Participant
Answer:  A & C.  Nice one crossrulz, LordNobady, MrStevenUND, BPerlman, ljbandres & edgar01.
eleshrudra
A and C
R.Elesh
Sangameshsh
A and c
