The Daily CLAD
Community Browser
Re: Keyboard Shortcuts: CTRL-Space then CTRL-D
SercoSteveB
Active Participant
If on the following Block Diagram you select the Add node and then perform a CTRL-Space followed by a CTRL-D.   What operation will LabVIEW (2009 onwards) perform?
a) LabVIEW will delete the Add node and maintain the wire between the Subtract and Multiplication nodes
b) LabVIEW will delete all nodes with incomplete input wiring
c) LabVIEW will create a Constant (containing 0) and automatically wire it to the unwired terminal of the Add node
d) LabVIEW will create a Control and automatically wire it to the unwired terminal of the Add node
Comments
Sumithra_Nagappan
Ans D
RAMESHB
Answer is D.
    Right click on the Block digram go to Numari palte select add function then select that function CTRL-SPACE then press  D now you got automatically Controls and Indicator.
RAMESHB
HI  Sumithra_Nagappan,
        can you explane please, how answer is B.
Sumithra_Nagappan
Hi Ramesh
Ans D is correct,while posting i typed it as B.
LordNobady
D ( by experiment )
A and B were (probberly) not correct becos with multiple inputs ( of differend type ) LV will not know what to do as a general function. it only inplementing it for a small set of functions is not logical. C and D seems ok. Test tel me it is D
Learning LabVIEW since January 2013
crossrulz
Knight of NI
D
A would be CTRL+R
C would be CTRL+SHIFT+D
GCentral
SercoSteveB
Active Participant
Nice one GM, finding the question subtext.
crossrulz
Knight of NI
Well, it helps that Quick Drop is one of my favorite features.  I was really happy when I started using 2011 because I could start using some of these shortcuts (exclusively using 8.6 and earlier before).  Now I live by some of them.  I even made my own plugin to fix up my VIs (I can be very OCD with some things).
GCentral
nmpundlik
ANS D.
sumapatil
Answer is D
Musale
can you tell any other shortcuts???
crossrulz
Knight of NI
I'll just reference you over to the Quick Drop Enthusiasts community site:https://decibel.ni.com/content/groups/quick-drop-enthusiasts?view=documents
GCentral
SercoSteveB
Active Participant
Answer: D.  Nice one Sumithra_Nagappan, RAMESHB, LordNobady, crossrulz, nmpundlik & sumapatil
As someone who started LabVIEWing before such cool features; I have to overcome muscle memory to use Quick Drop...wish I was better at it.
mini09
Active Participant
I`m not getting it should I select any option for that.
crossrulz
Knight of NI
You select the addition node.  Then press Ctrl+Space.  This will open up Quick Drop.  You can then press Ctrl+D to get the new controls.  You have to be in LabVIEW 2009 or newer.  But I'm not totally sure if Ctrl+D was available in 2009.
GCentral
mini09
Active Participant
Yeah Crossrulz got it. I was trying without selecting the addition block.. Now I got it thats great...
skian
D
