What does the following Block Diagram Symbol indicate?
a) The VI is set to run for a specified number of times
b) A Probe has been placed on a For Loop within the VI
c) The VI contains a For Loop which has the optional Condition Stop terminal enabled
d) A conditional probe has been placed on the VI to stop when a specific numeric value is detected
