Which of the following is/are TRUE regarding the Inplace Element Structure (an example of which is shown)?
a) Controls how the LabVIEW compiler performs certain operations
b) Is a place holder for a LabVIEW Structure type
c) Can operate on any data type that you want to maintain within the same data space in memory
d) Can increase memory and execution efficiency
