The Daily CLAD
Community Browser
Re: Less frequently used Structure types
SercoSteveB
Active Participant
Name the following Structure types from top to bottom?
a) Diagram Disable, Conditional Disable, Maths Script Node, Formula Node
b) Conditional Disable, Diagram Disable, Maths Script Node, Formula Node
c) Diagram Disable, Conditional Disable, Formula Node, Maths Script Node
d) Conditional Disable, Diagram Disable, Formula Node, Maths Script Node
Comments
LordNobady
I think it is B
Learning LabVIEW since January 2013
crossrulz
Knight of NI
B
I use three of those quite often (not the Math Script node).  I find the formula node a lot more readable when doing a lot of weird math.  I use the Conditional Disable Structure when I need the program to behave slightly differently when using an EXE vs the LabVIEW IDE.  And the Diagram Disable is great for troubleshooting (remove bits of code until you find your problem).
MrStevenUND
B
Conditional Disable I've used for one project.  Change a variable at the project level and you can have some lower level vi's act differently.
Disable I use all the time, great for troubleshooting as Crossrulz says.
I've only seen the math script used in NI's examples
Formula is great when you have to do several math steps.  Much cleaner, although I don't use it very often.
RAMESHB
Answer is B
nmpundlik
ANS B.
llx
B.
Sumithra_Nagappan
Ans B
somashekar_kako
answer B
Asha_Nagaraj
Ans is B.
sumapatil
The answer is B
jagadishj
Answer is B
adiveppa
Ans is B
SercoSteveB
Active Participant
Answer: B.  Nice one LordNobady, crossrulz, MrStevenUND, RAMESHB, nmpundlik, llx, Sumithra_Nagappan, somashekar_kakollu, Asha_Nagaraj, sumapatil, jagadishj & adiveppa
Popular one this one.  Nice to see a few new faces (welcome)
I have nothing further to add other than that provided by crossrulz and MrStevenUND thanks guys
mini09
Active Participant
Aggreed B....
ersmt444
Hello SercoSteveB
Please give some questions on these functions : Conditional Disable, Diagram Disable, Maths Script Node
Then it will be more clear that how to work with it.
