Assuming the Radix for a Constant, Control or Indicator is already displayed. Which of the following methods/tecniques can be used to modify the value of that Radix.
NOTE: More than one answer may apply.
A constant with Radix displayed is shown below to make the post more colourful.
a) The 'Appearance' Tab on the Properties Dialog box
b) The Text Tool allows the user to enter the Radix directly
c) A CTRL-RD key combination cycles through the available Radix options
d) A left mouse click on the Radix (with the appropriate Tool is selected)
