Which of the following data types can be converted into the Dynamic Data type?
NOTE: More than one answer may apply.
a) Numeric
b) Boolean
c) String
d) Numeric Array
e) Boolean Array
f) String Array
g) A Cluster containing only Numerics
h) A Cluster containing only Booleans
i) A Cluster containing only Strings
