The Daily CLAD
Community Browser
SercoSteveB
15 Comments
SercoSteveB
20 Comments
SercoSteveB
11 Comments
SercoSteveB
21 Comments
SercoSteveB
23 Comments
What are the values of TextFileSize(Bytes) and BinFileSize(Bytes) following execution of the VI?
Read more...
SercoSteveB
13 Comments
Which of the following is closest to the value of Elapsed Time(mSecs) following execution of the VI?
Read more...
SercoSteveB
8 Comments
Whilst building a VI you draw a selection box around the Block Diagram elements as shown in the snippet below and then select Create SubVI from the Edit menu.  Explain why LabVIEW DOES NOT create a SubVI?
Read more...
SercoSteveB
12 Comments
SercoSteveB
12 Comments
SercoSteveB
15 Comments
SercoSteveB
15 Comments
Whilst building a VI you draw a selection box around the Block Diagram elements as shown in the snippet below and then select Create SubVI from the Edit menu.  Which of the following most closely matches the state of your VI once the SubVI has been created?
Read more...
SercoSteveB
15 Comments
SercoSteveB
11 Comments
What are the values of TextFile1Size(Bytes) and TextFile2Size(Bytes) following execution of the VI?
Read more...
SercoSteveB
11 Comments
SercoSteveB
22 Comments
SercoSteveB
14 Comments
Consider the VI below that creates (or replaces) two text files, TextFile.txt and TextFileLooping.txt, and populates both files from the same (very important Smiley Wink) data set.  Assume the path exists and that both files are created successfully.
What are the contents of TextFile.txt and TextFileLooping.txt following execution of the VI.
Read more...
SercoSteveB
10 Comments
Whilst building a VI you draw a selection box around the Block Diagram elements shown in the snippet below and then select Create SubVI from the Edit menu.  Which of the following most closely matches the state of your VI once the SubVI has been created?
Read more...
SercoSteveB
15 Comments
Whilst building a VI you draw a selection box around the Block Diagram elements shown in the snippet below and then select Create SubVI from the Edit menu.  Does LabVIEW create the SubVI?
Read more...
SercoSteveB
15 Comments
You are tasked to write a VI that accepts, as inputs, a 2D array of numerical values (Numeric Array In) and a numerical value (Search Value) and outputs two numerical values (Row and Column).  Your VI must search Numeric Array In for occurrences of Search Value and output into Row and Column the row and column of Numeric Array In in which the last occurrence of Search Value was detected.
Which of the following VIs satisfies those requirements?
NOTE:  The search algorithm is not mandated but it can only search Numeric Array In once and the values returned into Row and Column must be the row and column of Numeric Array In where your designated search algorithm detected the last occurrence of Search Value.
Read more...
SercoSteveB
13 Comments
SercoSteveB
13 Comments
SercoSteveB
12 Comments
Read more...
