The Daily CLAD
Community Browser
SercoSteveB
20 Comments
You are tasked to write a VI?
INPUT(s): 2D Array (2D Samples Array) of DBL precision numerical values.
OUTPUT(s): 2D Array (Numeric Array Out) of DBL precision numerical values.
FUNCTION:  The VI must calculate the average value for each column in 2D Samples Array and append that average value to the bottom of the column.
Read more...
SercoSteveB
26 Comments
SercoSteveB
15 Comments
SercoSteveB
15 Comments
SercoSteveB
16 Comments
Assuming Numeric Value In is set to 1.  Which of the following VIs results in Numeric Value Out = 1?
Read more...
SercoSteveB
17 Comments
SercoSteveB
14 Comments
SercoSteveB
17 Comments
If Channel is set to 1, what are the contents of Numeric Array Out following execution of the VI?
Read more...
SercoSteveB
9 Comments
Which of the following satisfies the equation?
Read more...
SercoSteveB
19 Comments
SercoSteveB
9 Comments
SercoSteveB
17 Comments
If the VI below is created, saved and then executed twice, what are the contents of Numeric Array Out following the second execution?
Read more...
SercoSteveB
14 Comments
SercoSteveB
14 Comments
Which of the following shows possible contents of DAQmxData.csv following execution of the VI?
Read more...
SercoSteveB
24 Comments
SercoSteveB
14 Comments
SercoSteveB
14 Comments
SercoSteveB
18 Comments
SercoSteveB
18 Comments
What are the contents of Key Names Array Out following execution of the VI?
Read more...
SercoSteveB
16 Comments
SercoSteveB
14 Comments
SercoSteveB
24 Comments
