The Daily CLAD
Community Browser
SercoSteveB
8 Comments
Consider the VI, what values of LRI Identifier and Part Number Delimiter would be required for the VI to return 23456 in String Out?
Read more...
SercoSteveB
11 Comments
SercoSteveB
20 Comments
Which of the following is closest to the value of Numeric Value Out following execution of the VI?
Read more...
SercoSteveB
5 Comments
Assuming the File Path for each VI points at DataFile.txt and that the format of the DataFile.txt is as shown below.  Match each VI to the corresponding Numeric Array Out?
Read more...
SercoSteveB
13 Comments
Which of the following most closely matches the relationship between DAQmx Tasks and DAQmx Channels?
Read more...
SercoSteveB
24 Comments
Consider the VI, which of the following is the configuration of DAQmx Read.vi that would result in the data shown in Waveform Graph?
Read more...
SercoSteveB
17 Comments
Consider the VI, which of the following values for Sample Rate and Samples/Channel resulted in the data shown in Waveform Graph?
Read more...
SercoSteveB
8 Comments
SercoSteveB
12 Comments
SercoSteveB
8 Comments
SercoSteveB
11 Comments
SercoSteveB
10 Comments
SercoSteveB
12 Comments
SercoSteveB
16 Comments
SercoSteveB
14 Comments
You are tasked to write a VI?
INPUT(s): Numeric an U32 Numerical Value.
OUTPUT(s): Value is Even a Boolean Value.
FUNCTION:  The VI must return TRUE if Numeric is an Even Number.
Read more...
SercoSteveB
15 Comments
SercoSteveB
18 Comments
SercoSteveB has created the following VI but has poorly commented/documented his work (not for the first time Smiley Wink).  Which of the following most closely matches the functionality provided by the VI?
Read more...
SercoSteveB
23 Comments
SercoSteveB
19 Comments
SercoSteveB
14 Comments
Consider the VI, which Numeric Array In resulted in a Max Value of 5.56 and Fractional Index of 0.177829?
Read more...
SercoSteveB
20 Comments
SercoSteveB
10 Comments
INPUT(s): 1D Array (Numeric Array In) of I32 numerical values.
OUTPUT(s): 1D Array (Numeric Array Out) of I32 numerical values.
FUNCTION:  The VI must return in Numeric Array Out the contents of Numeric Array In with all duplicate values removed.
Read more...
SercoSteveB
19 Comments
SercoSteveB
19 Comments
SercoSteveB
20 Comments
SercoSteveB
15 Comments
