Troubleshooting Hardware
RoboRio 1.0 IP Issue, RMA Recomended
HI NI!  Oscar Fonseca (NI) walked us through a couple steps for debugging a roborio that is having issues getting the correct IP address over USB printer cable. The device has been wiped, factory reset, and put in recovery multiple times, and still has the same issues. Attached is the chat log from the FRC FTA slack channel! (Zach and Lewis are Mentors on the team and have been diagnosing the device).
(1,699 Views)
Accepted by SabercatRobotics
Hi, I hope you are well!   I've sent you a direct message to coordinate the repair of the device.
(1,666 Views)
Awesome! replied!
(1,624 Views)
@ThaysMolina check your DM's!
(1,583 Views)
Hi Sabercat Robotics
My name is Jessica, I'm with NI. My colleague Thays is currently out of office, so I've sent you a direct message to continue with the coordination of the repair.
(1,559 Views)
